DVD5 Problem
Posted by: HRDC99 on 09 September 2010
I have a bit of a problem with my DVD5 that I'm hoping someone can help with.
When playing certain DVDs (seemingly TV box sets in particular), the picture drops out. The sound continues so the DVD is playing fine.
It works fine on pretty much every other DVD but its annoying me.
I'm using a DVI to HDMI lead, if that helps.
I'm baffled! Smile
Posted on: 10 September 2010 by Richard Dane
Hmmm... not sure why it works OK on some discs and not others. To be sure, check your DVI - HDMI lead. Substitute if possible. Do you have any problems if you use component?
Whatever you do, make sure than any connecting or disconnecting of the DVI-HDMI lead is done with the TV off, as well as the DVD5. Hot-plugging can damage the DVI board.
