older prefix
Posted by: artist on 29 February 2004
i have an older prefix with the grey cable,is it worth sending it to naim to get it updated(how much £)i also getting a hum but when i remove the earth from the lp it disapears
Posted on: 29 February 2004 by Laurie Saunders
I ask myself the same question.
I believe that the all - in cost, ie prefix mod, new black snaic, & postage come to around £140
(I gave Naim a ring)
Laurie S
Posted on: 29 February 2004 by Bosh
The black SNAIC prefix upgrade is definitely worth it. The improvement is much like grey to black upgrade on the amps
If you can get at the Prefix, it is something you can do yourself. If not any Naim dealer should be able to in a few minutes
Caution: do not attempt to use a standard SNAIC by cutting off one of the plugs, it will not be long enough
Posted on: 29 February 2004 by Willy
As well as teh snaic update there's a mod that reduces RFI suceptibility and improves performance as well. Had this done in November. Can't say what the sonic improvement was as being a lazy git I left my LP12 in the shop for the duration. Whilst there my Klyde got bent but we came to an arrangement over a s/h Arkiv. Certainly eliminated the minor RFI issues I had.
Other thing worth trying is connecting teh earthwire to a spare socket earth on the prefix PSU.
Willy.
Posted on: 29 February 2004 by artist
i am using a naim cd and the prefix is powerd by a hicap i also use an armageddon power supply
