n-vi and optical input
Posted by: john R1 on 07 December 2006
am using the one and only optical input on my n-vi for my tv-drive, how do i get round it if i need to plug something else which also only uses the optical input ?
Posted on: 07 December 2006 by Mike1380
Posted on: 07 December 2006 by john R1
thanks for the responce mike, but i dont need a coax to optical connector, i need something that can take two optical inputs and ouput one optical input into the n-vi
sorry mike now see what you are saying, as the n-vi has two coax inputs, do you know if these connectors are any good ?
Posted on: 07 December 2006 by neil w
Posted on: 07 December 2006 by Former member
Thanks for that bit of info Neil.I have used tvcables before a few times ,just ordered the switch. John will let you know how good it is it should be here by this sat .regards munch
Posted on: 09 December 2006 by Former member
Hi John r the three way optical selector came today .I works very well ,easy to use, sound no loss at all, in all a good bit of kit for the money .kind regards munch
Posted on: 09 December 2006 by john R1
cheers for that munch, will order one although i dont need it yet might need in tthe future
Posted on: 14 December 2006 by james n
Maplin do the Toslink / Coax converter too - works well. I've got my NTL box into the digital input 2 via a Toslink to Coax converter and my Airport Express into the Optical digital input.
James
James
Posted on: 08 January 2007 by john R1
munch, am now using the optical selector, it works a treat, got my tv-drive and x-box 360 running into it no problems at all, thanks for reccomending it,
Posted on: 08 January 2007 by Former member
Hi John stuck mine under shelf with double sided pad out the way. It does work well.regards munch
munch, managed to get another component board for my pw6 for £15 what a steal, now have x-box 360 into component, n-vi likewise, and tv-drive into vga, pq from all three looks very good, think it will be a couple of years before i buy an hd plasma.
Yes John you say that now,I will give you a few months.regards munch
Posted on: 09 January 2007 by john R1
Ahem.......yes it WILL be a few years yet...LOL
Wifey watching
All these wires at the back are doing my head in...now...where did i put them there cable ties!
Wifey watching
Posted on: 09 January 2007 by Former member
nv/i stand alone one box,yeh right.regards munch
