DVD audio
Posted by: Peter Gear on 30 July 2001
Can someone tell me what DVDA is about and in what way it can be so much better than CD? Also, bearing in mind that I'm musing about replacing my CDI is Naim looking into this format?
There was also mention of yet another format by Sony and I think phillips - but it was dismissed as being not being a real competitor to DVDA.
Thanks for any info/comments
Peter
Being backward compatible they were able to compare directly with the same recordings on CD. It was stated that DVDA was much clearer and sharper than CD and the musicians felt it was much closer to the 'real thing'.
I'm always a bit wary of this type of thing. A DVD-A player will be optimised for playing DVD-A's, not for normal CD's. It's almost always the case (in my experience) that the backwards compatibility functions of such a player will not be a match for a player dedicated to the "obselete" format.
Chris L
The main selling points of SACD & DVD-A to the sound quality concious market for both SACD & DVD-A is a lower noise floor and wider bandwidth. As far as I am concerned at least the wider bandwidth issue is contentious.
The lower noise floor will make music easier to master, but if care is taken CD is capable of good results.
Moreover, I'm currently of the opinion I'd like to get the bandwidth and general sound pressure levels I know I can hear correct before moving on to stuff that I may not be able to (40 kHz cymbols).
In addition, there seems to be some ruining of great music by re-mixing to surround (drums and backing singers behind you is one example).
I would wait till this kind of 'showmanship' gets dumped till and the technology polished up before I invested my money.
Besides the current crop of SACD and DVD-As seems to consist of re-mixes or re-masters of ossified rock bands (do you really want 'Rumours' yet again or some Billy Joel?) and 'plink-plonk' boutique offerings from 'specialist' auiophile labels of dubious merit.
I'd stick with you CDI for the time being in other words.
The only viable offering that I can think of is surround sound. If all the new music comes out remastered as a surround recording, the mass market will think they're getting something new. (The mass market is also stupid.)
Another possibility is that record companies and audio equipment manufacturers will squeeze out the CD format, forcing the market to convert, whether it wants to or not. I'm not sure of the likelihood of this, though. If people want CDs, the market is likely to provide them.
Then we must consider on-line music formats. A friend from England visited my place the other day. He was drooling over my system, and actually recognized the "Naim" brand. It turns out that he was an audiophile before he started raising a family, with an LP12 with a Valhalla, etc. However, now he downloads MP3s off the net and burns them onto CDs. What is the world coming to?!?
Ultimately, it's not going to be our (a.k.a. the audiophile's) choice to make. We're a small segment of the overall market for music replay, and we really don't count all that much. The only ones who do are just like my wife: listening to Cher and U2, and blissfully happy with a cheap Panasonic midi system.
The world is a sad place... ![]()
-=> Mike Hanson <=-
It is almost certain that we could have a digital technology in 2001 that would blow away CD and analogue. I don't think either of these is it - and I don't think we'll get one for another 20 years. Bugger.
Jonathan - do you mean there are other formats out there being developed. In what way would they need to be different (to DVDA or SACD) to blow away CD and analogue.
Martin
Does this mean you would not change the CDI until a new format(s) is/are in place? I was thinking along the lines of a CDS2 maybe next year.
I can't see Naim being left behind in all this.
Peter
Both your current CDs and the thousands upon thousands of CD titles out there will all benefit from the change from CDI to CDS-2. I think this easily justifies the upgrade. At the moment there is nothing for Naim to get left behind from. I believe component obsolensce is a bigger problem for them than DVD-A or SACD when it comes to CD Player designs.
There are perhaps 400 SACD and DVD-A titles out there. I don't think this alone justifies a purchase. If want to try out a DVD-A or SACD player out I'd get one with good quality video (progressive scan, good RAMDACs etc) so at least you can watch films on it when you find the CDS-2 pees on the new technolgy from a great height!
Basically I mean the digital sampling should be good / quick enough to give us the effective infinite analogue granularity plus the noise (lack of) benefits of CD.
I suggest that as a starter you borrow (or even buy) the most dreaded of things. A CD test disc. Play the 19kHz tone. Can you hear it? Now play the 1 kHz LSB signal. Can you hear that? I very much doubt you can hear either - I can't all I hear is the hiss of my 135s. Your CDS-2 or whatever will reproduce both of these signals cleanly with very little distortion.
So maybe, the performance of digital coding system employed by CD does in fact out perform that of playback system (amps loudspeakers) being used?
If so, and you can't hear the limits of the current coding system why do you need something better?
For recording I can see the point. You need headroom for when someone kicks the mic stand and for mixing, but playback. Mmm. Debateable.
Now DVD-A is quite interesting. We are led to believe that we now need greater bandwidth and dynamic range. DVD-A allegedly delivers this. So it codes the analogue signal with great detail. OK, so now DVD-A watermarks this data. Watermarking it involves actually changing this data so that a cross-correlator on a recorder can pick out the watermark and then stop recording. This watermark is so robust it can withstand transmission on AM & FM radio, which posses less resolution than CD. MMmm. But we are told that this watermarking is inaudible. Mmmm
So on the one hand we need coding in incredible detail and the benefits are supposedly audible. On the other hand this detail is tweaked to such an extent that identifying features are not obliterated by very poor quality systems (where quality is defined as a combination of Signal to Noise and bandwidth a la Shannon) but this is inaudible.
Doesn't quite stack does it? Its is interesting to note that the patents on CD are close to running out though.
[This message was edited by Martin M on MONDAY 30 July 2001 at 20:30.]
[This message was edited by Martin M on MONDAY 30 July 2001 at 20:49.]
I totally agree with P. There are millions of CD's around which should keep you going for years to come.
Also DVD's are the same as CD's in that they are of varying quality. Many will beat the average £500.00 CD player but the likes of the CDS11 will be unapproachable for years to come.
Buy yourself the CDS11 and enjoy yourself.
Mick
Stepjem
I had understood that the original patent on CD format was expiring / had expired and that therefore there was now a race to find a new patentable format from which to extract some rent for another 15+ years. If this is true, and given that there appeat to be several willing manufacturers out there, adoption of either technology will depend on several factors:
1) Willingness of mass market retailers to push machines - my assessmnet of this is as pretty high, they always seem willing to put the latest doggy in the window
2) Willingness of labels to produce and retail the new format - if they believe the technology to be more copyproof then this is likely to be pretty high
3) Willingness of on-line and physical retailers to stock another brand - I suspect they need this increased inventory carrying cost like a hole in the head, they all have pretty crap economics anyway
4) Belief of average joe that he/she is getting something better - sadly, this seems likely to be pretty high
All in all, I suspect given these factors, adoption is likely to be faster rather than slower, unless retailers can hold back.
I would be surprised if companies such as Naim and Linn didn't have an eye on DVD-A and SACD but I think this is for the future (maybe) as far as you're concerned.
Found the news item below on Sony's official SACD web site (superaudio-cd.com). A little hop over to Linn Records reveals that they have about 7 recordings available in SACD. Since Linn CDs all carry the exhortation "This recording sounds even better on a Linn CD player", can a player be that far behind?
Linn Records re-release Hue & Cry on Super Audio CDRecords, has announced plans to re-release the Hue & Cry album, Next Move on Super Audio CD. The album was originally released on CD earlier this spring.
The re-release forms part of Linn Record's on-going research and development of new audio formats. The album, the second in the band's "jazznotjazz" trilogy, was originally recorded using Direct Stream Digital (DSD), a revolutionary 1-bit recording system developed jointly by Sony and Philips and used to make Super Audio CDs (SACD).
Now, with the launch of SACD in Europe, Linn Records is able to release a high-definition Super Audio CD and evaluate the record buying public's perception of this new audio carrier. The company has re-mastered the o riginal DSD recording to create an SACD master. The subsequent production of SACDs from this new master ensures that Hue & Cry's audience will hear their latest album in its most pristine form.
Linn Records grew out of an enthusiasm for music, the same enthusiasm which first led the people at Linn to get involved in Hi-Fi. The company's goal is to deliver the best musical performances to the listener with the greatest possible accuracy. "The Hue & Cry DSD/SACD project was an experiment into a new recording system," explained Philip Hobbs, Label Manager at Linn Records. "Always, we must first evaluate a new technology, however, we are very impressed with the sound quality we can achieve with DSD and SACD. There is little doubt that this represents an advance in music recording and replay. We are keeping a close eye on how the market reacts. We are confident that the end result has justified the experiment."
John Schmidt
"90% of everything is crud" - Theodore Sturgeon
