Bi amping new and old style NAP140
Posted by: robw on 28 March 2002
Any opinions on bi-amping with my current 'new' style NAP140?
Current System: LP12/Lingo/Ekos/Dynavector DV20X/ NAC72/ NAP140/ Linn Tukans.
RobW
Any amp over 10 years old (e.g. an old-style unit) will be in need of a service. Budget for this (£100-ish?)
It's worth pointing out that the standard SNAICs will lead you to one amp on the bass's, and the other on the trebles.
Although the benefit here is that you can put the better amp on the treble (standard Naim advice), and avoid channel imbalance, the best results are apparently to be had with non-standard SNAICs, so one amp does left speaker, and the other right.
Of course, Naim don't really recommend bi-amping (prefering to upgrade to a single, better amp)
Anyway, if you are going to do standard biamping (non-active), then using the standard snaics will put one amp on bass, and one amp on tweeters.
But, no need to get differant snaics (are there such things, anyway)--just modify the signal wires in your PSU so that two left channels go to one amp and two right channels go to the other amp.
Judd
Thanks for the information so far.
Rob W
If you want to go left/right rather than bass/treble, I'm sure Naim can knock you up a pair of SNAIC's for the job. I feed four 135's out of the back of a HiCap with 2 into 1 cables thay made for me.
Well it saves getting the soldering iron out on your HiCap ...
Judd
juddson1@msn.com
Last I knew, the pair of pre-made vertical bi-amp cables (DIN 4-4) cables (made of the same wire used for 250/135/500 interconnects) cost $150 US, if you don't feel inclined to re-wire your power supply...or if you're out of output sockets!
