noisey x-box 360
Posted by: john R1 on 29 December 2006
at the moment connected to my boys cheap portable tv via composite from x-box to scart, can' fault graphics even on his cheap portable, but the console is quite loud, also seem to be getting a hum through the connections, any ideas, am using the lead that came in the package.
Posted on: 29 December 2006 by neil w
hi john
not noticed any hum on mine, or it being noisey
but what do you mean by noisey
try a search on here for some answers
http://www.avforums.com/forums/forumdisplay.php?f=206
neil
Posted on: 29 December 2006 by john R1
neil, i mean the sound like a noisey computer, i think it must be the fan ?
Posted on: 30 December 2006 by Allan Probin
John,
The only time I ever hear ours is when I'm close up to it fiddling around with cables.
Are you using it horizontally or vertically? Ours is horizontal but I notice that if it was vertical the outlet for the fan would appear to be on the underside. The feet don't seem to give it much clearance so maybe it gets hotter this way round and the fan works harder.
Allan
Posted on: 30 December 2006 by john R1
allan, its vertical at the moment, see if i can make some space to try the other way, cheers
Posted on: 30 December 2006 by RoyleBlue
Me and the boys got one from Santa this year - sounds like a 747 taking off which ever way it is!
Posted on: 31 December 2006 by john R1
royleblue, i think its very slightly quiter layed flat, but still quite loud,
