equipment support tweaks...
Posted by: ken c on 17 May 2001
you will recall quite some time ago i had some interesting results using audiophile bases together with my QS for my cd2 and nac52.
now with the isoblue, things have changed somewhat. i did try to put a base on the top isoblue shelf and then my cd2 on top of that. there was little difference -- but what difference there was, was negative. music was a little "slower" (these words we use???).
ah!! i thought, there is this other tweak to put some 3/16" ball bearings under the base the space left when you remove the rubber feet. did this -- quite tricky but do-able netheless. result -- sound became so harsh it was definitely interfering with the music.
so i have now retired my "bases". i MIGHT try them under the supercaps or 250's (on the projekt)if i feel like messing about -- but i doubt the result will be different.
just thought this could be of interest.
enjoy...
ken
