Becker Grand Prix
Posted by: i am simon 2 on 15 November 2006
I just changed the stereo in my car for the Becker Grand Prix, and I must say what a fab gadget it is.
It has built in bluetooth connectivity to the mobile phone, and it comes with a microphone, which after half an hour was neatly installed on the A-pillar with the wires all hidden behind the trim.
When someone phones you, the music stops, and you can press a button on the unit to answer, it even has caller id on the display. If you want to make a call, you can use the controls on the stereo, even dial numbers or scroll through recent incoming or outgoing calls.
Additinonaly there is great ipod support with playlist, album, artist, genre etc support. The ipod wire is a bit pricy as an extra, but well worth it.
I am not meaning to plug this product, but I was so impressed with it I thought it worth a mention. Furthermore it sound much better than the old clarion I have removed from the car, and even with thr standard speakers it sounds much better. It shows that the source is more important than the speakers. Now where have I heard that before.......
Simon
Simon
