ps3 and blue-ray
Posted by: john R1 on 19 January 2008
got me ps3 yesterday, only got 1 blue-ray film at the moment resident evil extinction, pq seems about the same as my tosh hd-dvd player, my 1 and only game drakes fortune looks and runs very well, it took me ages to get it to output at 1080i, not sure if its the realy bad on screen menu or if i am getting to old, sound also seems ok via optical to n-vi ie dd 5-1
Posted on: 19 January 2008 by Tuan
Make sure to do the firm ware updates to the current version. You can down load the update using computer and transfer to USB memory stick to update it or you can do it directly if your PS3 connects to the internet.
Posted on: 20 January 2008 by john R1
Tuan, the 40gb ps3 does not accept memory stick, its does have a built in wi-fi so will try to get conected later onto our wireless internet connection.
Posted on: 20 January 2008 by Tuan
John
After you update the firm ware, you will have a much better PS3 especially on the DVD player section. You will enjoy the upscaling option that not many blue-ray or HD-DVD can match.
Posted on: 20 January 2008 by ryan_d
Got my ps3 3 days ago now and updated it yesterday. Vision is wonderful. Just need a blu-ray movie with lpcm soundtrack to test it out.
Ryan
ryan-d, just updated mine,when i tried the lpcm out-put i could only get a stereo out-put i had to select bitstream to get 5.1
Tuan, i will try a reg 2 dvd later to see how it compares to the n-vi
John,
hmmmmm that doesn't sound too promising. I'm sure it lists the ps3 as being able to do 5.1 with lpcm. Not got a film to test it on at the mo so its not a worry at present.
They are apparently doing an update so it will be able to decode dolby ad dts hd. No timescale given as to when though.
Ryan
Posted on: 20 January 2008 by neil w
john
im sure the only way to get mc/lpcm is via hdmi
neil
Posted on: 20 January 2008 by sundar
hi everyone
I wonder if any of the members help me setup my PS3 with my infocus IN82. I setup home cinema with this projector,NVi and HDMI switching device.This works well with my sky HD and DVDs brilliantly.
The PS3 software upgraded to latest version. I can use this with my Pioneer plasma very well with full functionality both vision and sound. The moment I connect to my cinema with or without the switching gear I can not get any picture.I tried help line which is poor and I am about to return this machine. Are there any other tricks to be tried.
I also use NAC112/NAP150 for my front speakers B&W CDM1NT.
Thanks in anticipation
sundar
neil w, am now using hdmi will try lpcm next time i use the ps3
Posted on: 22 January 2008 by ryan_d
John ,
have you tried it yet through hdmi? waiting for your results.
regards
Ryan
Posted on: 23 January 2008 by john R1
ryan-d have moved the ps3 into the bedroom as wifey is always watching the main tv, now rigged up onto a 26" toshiba lcd, outputting stereo via hdmi and lpcm, games look very good, still not convinced about blue-ray being the be all and end all, looks ok ? having said this i am not a lover of lcds anyway, and much prefer my fujitsu plasma, each to there own.
Posted on: 24 January 2008 by ryan_d
Yeah John I know what you mean. I was impressed with the picture though but wsa wondering about hte 5.1 sound via hdmi. I'm only getting pro-logic through my amp as I am using optical cable. Still sounds not too bad.
Ryan
