Ghost in the machine
Posted by: Bruce Woodhouse on 19 April 2001
Any ideas?
Every so often I hear a foreign radio signal through the speakers, without switching on the tuner! This is volume independent and continues in the background if a source is playing. I think it appears during periods of high atmospheric pressure.
My assumption is that something in the system is acting as an aerial.
The set up is CDX/XPS/102/Hi-Cap/140x2/IXO/Credo all via naim interconnects but Chord Rumour speaker cable. All original power leads and a dedicated mains spur. I have an Audiolab 8000T tuner and decent FM aerial but this is not powered up when the signal appears.
Do I need an electrician or a psychiatrist?
Posted on: 20 April 2001 by Linds
1. Is it actually a radio signal, or could it be it's your neighbours singing or having a chat, etc. next door?
2. Is it a semi-detached house you live in, with thin walls?
3. From what country do your mumbling neighbours originate?
4. Did I say 3 questions? I meant 6
5. Can you actually receive this station when actually using your aerial?
6. Are your neighbours interesting people?
Posted on: 20 April 2001 by Cheese
Bruce,
You don't need a psychiatrist at all (at least from what I can read big grin ) - this kind of interference is an old and very common problem, and it occurs more on some days than others (depending on the weather?). Funnily, it happened on my old B&W speakers, on my new gear it has disappeared (but I have moved also).
Check the Web about that - there must be plenty of information.
Bernard
