Chris K./ Messing with the tweeters........Help...
Posted by: Onthlam on 24 August 2003
Chris,
Could NANA come up with a manual to complete this tough but necessary task?
In the mean time,is there a bench mark for the amount of torque for the Phillips screws?
Marc
She asked for a Grand piano.
All I could give her was an upright organ...
Marc
Posted on: 24 August 2003 by dave simpson
quote:Could NANA come up with a manual to complete this tough but necessary task?
Great idea Marc! ...and is it me or is a DBL manual missing from the Naim Main Web-site? Also...(and until Chris replies)...have you looked at page 10 of the online Axent owner's manual (which has suspended tweeter adjustment tips)?
regards,
dave
Posted on: 24 August 2003 by Paul Stephenson
Its almost impossible to describe the dbl tweeter plate set up its all about feel! but it could read adjust screw through grommet and move fins on the plate until it bounces freely!
If you look at the axent tweeter set up as Dave suggests it will give you a good idea.
I would leave it to your dealer or Chris. Bend the plate too much and you screw the whole thing up!
[This message was edited by Paul Stephenson on SUNDAY 24 August 2003 at 21:35.]
Posted on: 24 August 2003 by Onthlam
Paul,
Agreed......
A thought.
Is the amount of work,and result worth waiting monthes before something could be done? I would guess that when adjusted there is truly a wonderful transformation in the sound.
Could this be considered something like an annual upkeep task that if sent to NANA, they could complete this and send the mid/tweeter sections back to the house?
Yes,charge me for the time....
Thoughts?
Marc
Agreed......
A thought.
Thoughts?
Marc
Posted on: 25 August 2003 by Paul Stephenson
Yes its worth waiting for, if you mess up the plate it will have to be replaced, overbending deforms the plate.
Once set up, it should not change position if the unit is not moved. The set up needs to be done in location as the internal wires are a part of the suspension action.
Posted on: 25 August 2003 by Onthlam
Dave, looked at the Axent manual.
For me, there is not enough,How to, to complete the task. The pictures are a good start..Not enough text to feel good about moving forward.
If I remember correctly, there was no mention about the wires. This aspect seems to be the critical aspect of the tweak........
Knowing that there is an opportunity and having no means to optimize can be frustrating...
Marc
Marc
Posted on: 25 August 2003 by dave simpson
Originally posted by Marc Newman:
"Dave, looked at the Axent manual.
Knowing that there is an opportunity and having no means to optimize can be frustrating..."
I understand where you're coming from Marc. Have you thought about calling CK and having him walk you through the procedure over the phone? I'm sure he'd be happy to oblidge.
regards,
dave
regards,
dave
