Cartridge recommendation
Posted by: Adolfo Aguiar on 28 August 2001
My analog front-end is Linn LP12 Valhalla, Ittok and DV10X II.
I have an old Karma that needs to be refurbished.
Should I do that (cost 350UKP) or go for a DV20XL (cost 300UKP).
Is it possible to use a Prefix in this configuration?
As I am sure you know, your DV10XII is a high output MC that is designed to work into a MM input. The DV20XL and your old Karma are both low output MCs and designed to be used with a normal MC level phono stage. The Prefix is available both as a MM stage, and two flavours of MC - S for the vast majority of MC cartridges, and K for the early Linn cartridges such as the Troika and your Karma. In all honesty there is not a massive difference between the two kinds, but if you know the cart that you plan to use it is worth ordering the correct Prefix for it.
Tony.
Are you sure that there are just two flavours of MC prefix?
Not sure at all, in fact I bet you are right! I just thought I would answer the post as no Prifix owner had come forward ![]()
Tony.
The Stageline is available in all the Prefix flavours plus standard MM.
Joe
Any of you know where I can get information on how cartidges should match up with phono stages. I've got a Prefix "K" and would like to get some guidelines on gain and impedance matching to figure out which cartridges are the most suitable. I was considering the Lyra Helikon for my K but it seems like the output is better suited for an E board. Same seems to go for the Dyna XX2. There are at least 2 Forum members that have mated the K with an XX2 so it must work, but what's the downside?
Arthur Bye
The only trend I've discovered (with plenty of exceptions -- but that's why a wrote trend) is that the smoother and more coherent a MC cartridge's response at 20 kHz or beyond, the more likely it should be matched with the K boards.
Unfortunately, it's a suck 'n' see situation, one that's relatively easy to do with phono boards but a huge pain in the arse with a Prefix or Stageline.
Joe
I personally find Dynavectors a little 'hot' in the treble with K boards and so I would sggest the use of an 'S' prefix with these.
I hope this helps!
Thanks for the information. I was unaware of the low output Helikon. I'll have to go check that out.
Arthur Bye
