Exporting from HDX to iTunes
Posted by: busaganashi on 25 June 2009
Has anyone figured out how to add HDX ripped files to iTunes with the album artist and other information intact?
I tried to "add to library" and all it imports is the song title. I really don't want to manually go through each artist and write the names.
Posted on: 26 June 2009 by js
I haven't tried it with Itunes but this works in Media monkey or WM. Import what you want to a folder. Drag one album at a time into a destination folder for the player to import from. Once that single album is imported, it's not mixed with others and you can have the player do a meta data search and your done. In MM it takes less than 1 min per disc. I suspect that you may run into trouble with Itunes as Apple likes to control where content comes from.
Posted on: 26 June 2009 by busaganashi
Unfortunately, but only for this purpose Smile, I'm using a MAC.
Posted on: 27 June 2009 by David Dever
This is not possible–you will need to update artist and album information manually–another limitation of iTunes, independent of platform. There are other PC-based applications that will elegantly handle this, but, unfortunately, not on the Mac, sorry....
Posted on: 29 June 2009 by michael1702
did i miss something or is there a way to access the hdx ripped files already?
thanks,
michael
