What next ?
Posted by: Lightkeeper on 04 September 2003
Hi,
I own CD5/Nait5/Intro2/all Naim cables.
A brand new FC2 will be on my shelf soon, but what upgrade should I consider next?
I would like to pass 112/150 and don't want to buy anything from second hand.
Here are my thoughts:
1. Sell CD5 and buy CDX2
2. Buy 202 and power it from primary output of FC2, while CD5 is feeded from second FC2 output. Nait 5 will be temporary used like power amp in that case.
3. Buy 200 and use Nait5 as a preamp, ofcourse, power it from FC2 and CD5 to. This last option is not ideal I believe, because source and pre-amp section should come first?!
What do you think?
Did you have some other combination for me to consider?
I will apreciate your advice,
Thank you.
Ozren
What do you think?
Thank you.
Ozren
