Correlation between technical data and sound quality
Posted by: Arye_Gur on 01 May 2002
We talked about this subject several times at the past, and few of us (including me) thought that because of the nature of our hearing system, we can hear things in a way that can’t be measured.
I remember that Ross said that he read an interview with the first engineer of Exposure and he told that they built the amps by the physical and electrical principles.
I think that Naim are doing the same – and all the other manufacturers too.
So how it comes that there is no correlation between the data sheet and the quality of the sound? If the manufacturers are following the technical data, how it comes that a system with better data sounds worse than a system with less quality technical data.
Now I think that I know the answer -
First, there is a correlation between technical data and sound quality.
But the question is WHICH DATA – and that is the big secret!
The technical data that published by the manufacturers is only a part of what the manufacturer is taking care of. This part is published because of historical reasons that were common in the Hi Fi papers many years ago, and it is common nowadays too, but it says nothing.
Each manufacturer has a batch of data he thinks is the most important to achieve the right goal with it. Each manufacturer works hard to bring the data he thinks is the right data to high and accurate level. And as each manufacturer emphasizes what he thinks is the important data – it makes the differences between the various components.
So it is not that we can hear unmeasured phenomenon – we simply don’t know
what are the technical points that the manufacturer is taking care of.
And it doesn’t change the main point – we can’t trust the technical data sheet,
We must trust our ears!
Arye
Arye
