Hummmmmm on Nait3
Posted by: Cheese on 03 May 2003
I will probably purchase the s/h Nait3 I have tried for a week now, the only problem being a mechanical hum, which stops when I put something heavy on it. When I remove the case there's of course no vibration either.
There is some space left in the amp so I thought about cutting a tennis ball to the right height and insert it into the Nait.
This will probably work, but does anyone of you know a more elegant solution ? Thanks.
Cheese
Cheese
