hdx RIPPING
Posted by: craigdonnelly on 26 February 2010
Good evening, just a quick question. When the HDX is full will it rip CD's onto a seperate NAS drive or would you have to rip the CD onto the NAS using you PC etc?
Posted on: 26 February 2010 by gone
With the latest firmware, you can rip directly to the NAS. You define a 'Music Store' on the NAS, and then you simply make that the target for the ripping.
The Music Stores have a priority which you can set, so if one is unavailable (e.g. 'full'), then the next one in the list takes over.
You can also move music between stores if that takes your fancy
Hope that helps
John
Posted on: 26 February 2010 by craigdonnelly
Thank you John. Have a nice weekend.
Certainly will - the HDX is sounding divine through the DAC....
