Copy Protection causing problems?
Posted by: garyi on 26 October 2003
I got some music this week off some one. I put it in uncompressed format onto the ipod. (I own all of them on record, which I can't be arsed to import)
when I got home I used some freeware to get the tracks off the ipod without trashing my library.
The long and short of it is that I burnt around 9 CDs.
Five of them have been fine, this includes big bud, Smog and Be bop deluxe.
However some refuse to work in the CDi.
I remember that some apple software disks would allow you to copy them to to a hard drive, but would always balls up a CD burn.
Thing is the cds is recognised fine on the mac, but the CDi does not want to know.
So my question is, why is the CDi perfectly happy with some burnt CDrs but not others?
FWIW I have never had troubles with CDRs before, also I tried mixing some playlists, but as long as the problematic album tracks are on the CD, it will not play in the CDi.
Also the burning took place in the same application, in the same day, using the same format with the same blank CDs. The ones that did not work were redone.
Odd eh?
Posted on: 27 October 2003 by Bosh
What I find odd is that CDRs burnt on my home Carrera PC work fine on that and my CDS3 and CD2 but stick, skip and jump on my Dell work PC Confused
Posted on: 28 October 2003 by andy c
When copying the CD-rs with copy protection, its best to slow down the write speed to say 4x. I have just done this whilst copying such a cd, and said cd now plays fine in the car (A copy at 48x didnt).
This was copied using CLONYXXL via Clone Cd.
Hope this helps...
(Credit for the above to DArkan9el's help)
