Which coax cable?
Posted by: crsm on 10 October 2008
Hi,
I notice that the new Pace Sky HD box has a digital audio coax output and was wondering if anyone has any recommendations for coax cables to connect to an AV/2?
Cheers!
Richard
Posted on: 15 October 2008 by Flame
I'm using Chord's coax cable and am very pleased with it. Don't recall the name but I believe they only make one type of coax cables.
Posted on: 15 October 2008 by garyi
I recommend one that is long enough.
Posted on: 16 October 2008 by djftw
Actually Chord make three Coax cables ranging from the fairly modestly priced Codac at around £40 to the Signature which is over £200 (for 1m lengths). Naim also have their own DC1 which I think is about £175, so probably overkill for a Sky box, the Codac would probably be my choice on the basis that I have never been dissatisfied with a Chord product, buy if I was on a budget I'd be pinching some low loss satellite cable when the guy came to fit my dish and buying a couple of plugs on fleabay...
Posted on: 16 October 2008 by RAM
Naim make a Digital Coaxial Cable called the DC1.
It's exceptional.
Posted on: 17 October 2008 by james n
Posted on: 19 October 2008 by crsm
Thanks for the advice, looks a Chord Codac cable is the one I'll be getting.
Cheers!
Richard
Posted on: 24 October 2008 by Frank Abela
Richard,
I hope I'm not too late - although it's a good cable the Codac is nothing like as good as its bigger Prodac Silver Plus brother. The prodac is our best-selling cable for a reason - it punches well above its weight for performance. The Codac is abut £40 and the Prodac is around £65.
Posted on: 26 October 2008 by crsm
Hi Frank,
Thanks for the advice, not too late as I'm out of the country at the moment and will be picking up a cable when I'm back in a couple of weeks.
Cheers!
Richard
