That Ebay Hicap
Posted by: John Bailey on 10 November 2001
Right, I've just bought that Hicap (the one with the red caps) off Ebay. This will be used with my existing NAP140 and initially a NAC42.5 which I intend to replace with a NAC112/Stageline next year sometime. The rest of the system is an LP12/Valhalla/Akito/Blue Point and Kans.
The amp is mint but would I'm sure benefit from a service. What about the Hicap? Is there much benefit of having this serviced given that it is (presumably) much less stressed than the power amp? The NAC42.5 works well but the number of inputs is a limitation and it has a slightly crackly volume control - I'm not sure that a service is worth the cost really.
Eventually I also want to add a Naim CD to the system - has anyone any experience of a CD5 with Kans or is a CD5 a waste and I should go for the CDX when it arrives in the new case? Also, do Naim still sell the ARO tonearm?
You can tell that I am not that focussed in my system builing!
Any advice gratefully received.
John.
