Help on I Explorer
Posted by: Manu on 10 February 2004
My office Internet Explorer 6 can't open a new window anymore. For example, on this forum, i can't make a reply: the reply window opens but nothing appears in it(the fast reply works) or if i clic on a link to an other site, nothing happens.
I have tried reinstalling IE but nothing changed. I use WIN98SE.
Any ideas?
Emmanuel
Euphonie
All opinions are my own, and reflect those of the organisation i work for, even if not stipulated.
Posted on: 10 February 2004 by Chris Brandon
Manu,
(Assuming that you haven't altered / downloaded anything that could interfere with the operation of internet explorer).
Try checking the security settings in your Internet Explorer...
Launch I.E,then
Tools,internet options,security.
You could also try "restoring defaults" ....
Tools,internet options,advanced.
Chris
Posted on: 11 February 2004 by syd
Hi Manu
have you recently installed a Pop up Window Stopper program. I use Pop Up Stopper and although I've set it to ignore this domain I still have to hold ctrl key to get the window for replies, new topics etc. At the bottom of the main Explorer window I get a message saying either "Error on page" or " Javascript:void(0) after the little info triangle. As I say holding down the ctrl key allows the pop window to open.
Yours in Music
Syd
