Remote problem with CDX...
Posted by: bob atherton on 23 November 2001
My remote for the CDX is no longer working when the 'numbers' are pressed. All the other functions work perfectly.
Has anyone else ever experienced this? Is it a fault with the remote or the CDX? It all sounds as good as ever, thank goodness. Any help or suggestions would me much appreciated.
Bob.
Posted on: 23 November 2001 by Hammerhead
Hi Bob,
All you have to do is press the CD button at the top of the remote. You then should be able to use the number buttons again.
Steve
Posted on: 23 November 2001 by bob atherton
I was being really dumb!
Bob. roll eyes
