Naim with Tube CD Player
Posted by: king on 06 March 2002
A freind recommended Jolida CD Player which runs a tube output stage. I heard it on other system and it was beautiful. Warm, big, and very very analogue.
This could be my next step from my Marantz now. ![]()
Originally posted by James:However, if you want an analogue sound, you really need to spend serious money on a CDP or go cheap and buy a good used turntable.James
Thanks James,
I'm looking for a used CD3 but seems like it a hot item that no one wants to part with.
I'm running a modified VPI HW19 with Dv10x4 now, but CD player is soon to be my main source as software for turntable is getting less here.
Apart from Jolida, PLanet and Rotel is also on the card, and budget is a main issue here.
Cheers.
King
Jun
John
http://www.hifi-notes.com/ah1-en.htm
Steve
http://www.tntaudio.com/sorgenti/tjoeb4000_e.html
Originally posted by Sigmund:
My Nait 2 is currently driving my new Njoe Tjoeb 4000 which I bought with the upgraded power cord and E88CC tubes. I'm hopefully at the tail end of burning it in. I hearing a noticeably extended treble, a tighter bass and a soundstage that is much greater than my Sony ES208. Here's the url for the review that sold me.
Sigmund,
please keep us updated as I'm interested in this player for one of my systems.
Steve
Initially, Gillian Welch's first album and one of my wife's favorites, was unlistenable. *Way* too forward, edgy and instantly fatiguing. With the cd player's volume all the way up, set at 20, it's noticeably less awful after a week though I can't listen for long. I've turned down the volume on the cd to 14 and that seems to make a real difference.
More to follow.
I used to have a Teac transport running into an AudioNote DAC2 Signature. This fed into my then 32.5 then 250. I used this for about 5 years happily and then tried a CD5. The comparison was night and day in the CD5's favour.
The valve output stage of the DAC2 did give a warm open sound but compared to the CD5, it had very limited bandwidth and was particularly weak on lower frequencies.
I think that much will depend on the rest of your system and the sound balance that you prefer.
Good luck
Raphael
