Bi-Wire Adaptors
Posted by: droodzilla on 30 June 2007
Just browsing past posts about biwiring, and came across a link to these:
phonosophie
Any thoughts on whether such devices are effective? I use 2 x 3.5m NACA5 into Spendor S6e's, with whatever jumpers came with the speaker. Would these phonosophie thingies improve matters?
Posted on: 30 June 2007 by GraemeH
phonosophie
Just solder a short 5cm length of NACA5 about 5-10cm before the speaker end of your cable to plug into the low frequency inputs. Works fine on my S5e's.
Posted on: 30 June 2007 by droodzilla
sorry - any way of moving this thread to the correct forum?
Posted on: 30 June 2007 by fidelio
just start over droodie (or do a little searching). meanwhile, your naim dealer will create an "f" termination on your naca cable.
