NDAC and Virgin STB
Posted by: vandergraafuk on 09 September 2010
Hello forum,
Just wondering if anyone else has experienced this issue. The virgin box is connected to one of the NDAC inputs via a SPDIF over optical. All the channels play perfectly out through the main system except for the HD channels. I seem to just get what sounds like digital white noise. Is this because its not being outputted as standard two channel audio, and is some funky dolby 5.1 that the NDAC cant decode??? Thoughts greatly appreciated
Posted on: 09 September 2010 by Eloise
It's sending Dolby Digital encoded audio on the HD channels - there's probably an option in the settings to send "normal" stereo - labeled Linear audio (vs Bitstream for DD) or just Stereo (vs Multi-channel).
Eloise
Posted on: 09 September 2010 by vandergraafuk
Thanks for the advice Eloise. Will have a look tonight and set it to just stereo.
Posted on: 10 September 2010 by vandergraafuk
Can you adam and eve it. You can change from dolby digital to 2 channel audio down the HDMI cable but this does not do owt the SPDIF out the back of the box grrrrrr!
Posted on: 10 September 2010 by james n
I'll take a look at my box settings tonight when i get home as i have mine set to 2.0 PCM feeding a DAC. Im pretty sure its in the HDMI overide settings.
James
Cheers James I have one of the Cisco STB 4585DVB
Ah ok - i've got the pace V+ box. Try HDMI overide 'off' if your box will do it. Just checked the n-Vi display and its showing PCM 2.0 whether on the normal or HD channels. If i turn HDMI overide 'on' then HD channels show Dolby Digital on the display.
James
