CD5 misreading cd's
Posted by: Theo on 30 August 2002
My CD5 misreads some of my cd's. After closing the door, the CD5 spins the disc and a few seconds later I hear a typical sound ("clunk") , after which the display gives no track numbers.
What is the cause and cure?
- puck?
- cleaning cd?
Theo
Posted on: 31 August 2002 by herm
Hi Theo,
the bad news is the CD5 just won't accept some damaged discs, while other, less sensitive CDPs will.
However there is a kind of disc with a rather thin, transparent centre Naim doesn't like too much. Particularly Teldec / Warner and affiliated labes uses this make a lot.
In those cases it helps to paste some cellotape ("plakband") in a cross over the centre, and cut out the hole again. This way the puck gets a little more grip on the (thicker) centre.
It is a hassle, I agree.
I saw you use VDHul First Ultimate. When I compared it with Nordost Blue Heaven in my (second) system VDH sounded a tad duller.
Herman
Posted on: 31 August 2002 by garyi
If the CD5 used to read the cds in question then its likely to be the puck, bite the bullet and buy a new one, they are about 20 quid.
Posted on: 31 August 2002 by silklee
I have no idea whether it is a recommended practice or not.
On the underside of the puck there are 3 rubbery 'things'. after use it gets kind of flat. You can squeeze to make them round again. It works for me sometimes.
Posted on: 31 August 2002 by max in hampshire
Hi Theo
My virtually brand new CDX does exactly the same, so perhaps it is unlikely to be a worn puck.
With me it happens mainly, but not solely, with Naxos CDs. I have noticed that sometimes it will happen with a CD that previously has played normally. Interestingly it happened on a CDX demo I had at a dealers too so it does not seem to be unusual.
In my case it only happens rarely so I have not got too concerned about it as yet. Though if it persists I would certainly want it dealt with under the warranty in due course.
Downwards pressure on the CD often cures it but I doubt that this is a good thing so I only apply any pressure very gently. More a case of making sure the CD is properly seated really.
I shall watch with interest to see what advice you get from others.
Max
Posted on: 01 September 2002 by Theo
Herman,
The Nordost sounded indeed more dynamic and a little brighter than the VDH, which sounded more relaxed and darker. In my system I needed that little "duller" sound.
But this was all before I got my CD 5 and an old Philips did the job.
Now the standard Naim is the interconnect. My dealer offered to remake the VDH withe DIN connectors to fit the Naim. I still doubt whether I'll take that opportunity.
Theo
Posted on: 01 September 2002 by garyi
Theo, how come you are a 'Somebody' and everyone else is a 'Member' or 'Novice Member'?
Posted on: 01 September 2002 by herm
Because of his body, naturally.
Posted on: 02 September 2002 by Theo
Garyi,
Because I own a naim cdp.
Theo
