more cables! Din to jack???
Posted by: Andy Moore on 25 May 2001
What would be the best solution for connecting a minidisc personal to a Din socket?
Would it need to be a jack-phono cable with a phono/Din adaptor or is there a more elegant solution?
Andy.
Posted on: 25 May 2001 by Michael Dale
I know Chord used to do a mini jack to Din lead for about £20. I made one up so that I can record from my 82 as well as play back into it. I would speak to naim directly to see what they suggest.
Best wishes,
Mick Dale
Posted on: 25 May 2001 by Andrew L. Weekes
Andy,
Chord can definitely do a Chrysalis in this format. You can order playback only, or record & playback.
It's the same as the leads they make for Walkman Pro's.
Andy.
Andrew L. Weekes
alweekes@audiophile.com
