Home made CD's - ripped to play on UNITI
Posted by: djh1697 on 28 May 2010
Quick question
It is merely for convenience, I have some home made CD compilations ripped from LP's.
Will a Uniti play these if they are in WAV format?
I propose a directory with an artist, the next the album name, then the track.
i.e.
\BLUE NILE\HIGH\BECAUSE OF TOLEDO
\ARTIST\ALBUM\TRACK NAME
Posted on: 28 May 2010 by Aleg
Originally posted by djh1697:
Quick question
i.e.
My guess would be that the CD would have to be proper Redbook audio CD and not a data CD with audio files.
You could of course just put the audio files on a USB stick and play them like that.
aleg
Posted on: 28 May 2010 by djh1697
aleg
The CD's play on a standard Philips CD373, on the market well before CDR's where available, who knows ? What is the difference between files stored on a USB stick or a NAS drive? How about a USB hard drive?
aleg
You can try it yourself easily of course, but I noticed Uniti specs say Redbook and that has a different structure on the CD then when you make a data disk with audiofiles in a directory structure.
Not so much in that case apart from having to have a network connection of sufficient bandwidth when using a NAS. I'm not sure if Uniti can directly access network shares or if it can only access a NAS through UPnP streaming. In the first case you would require Samba which is always available on a NAS and inthe second case you would require some streaming server which is also often present on a NAS.
Not much difference to a USB stick, just larger.
aleg
Posted on: 01 June 2010 by djh1697
When I rip a redbook CD to my NAS drive, the file/directory structure is
\MUSIC\BLUE NILE\BECAUSE OF TOLEDO.WAV
When I rip a homemade CD to my NAS drive the file/directory is
The only difference is i have renamed the file myself, so why would it not work ?
Posted on: 01 June 2010 by PureHifi
When you rip a Redbook CD to Hard disk it is no longer a redbook CD, it is now individual WAV files - CD's do not use WAV format (although it is a matter of similarity) but instead it is CDDA..
Do a search of wikipedia and all will be explained.
A CD player that is expecting a redbook CD to read from may not read a bunch of WAV files not matter how you organise them...although some may..
