Itunes / Xp laptop / Dac help
Posted by: kev 1966 on 04 August 2009
Hi I want to try something with only a small outlay so looking for some help please
I have a second laptop (running xp) I have just setup and loaded with itunes (lossless) only one cd so far, I would like to connect this to my amp by means of a Dac
Which Dac is the best to start with? was considering the Cambridge but willing to listen to advice
Kev
Posted on: 04 August 2009 by garyi
Is it a USB dac you are after or does you laptop has SPDIF out?
Posted on: 04 August 2009 by kev 1966
Gary,
Maybe really stupid but how do I know if it has SPDIF ?
Kev
Not sure if this helps:
5-in-1 integrated Digital Media Reader for Secure Digital cards, MultiMedia cards, Memory Stick, Memory Stick Pro, or xD Picture cards
3 Universal Serial Bus (USB) 2.0
1 Headphone out
1 microphone-in
1 VGA (15-pin)
1 TV-Out (S-video)
1 RJ-11 (modem)
1 RJ -45 (LAN)
1 notebook expansion port 3
1 IEEE 1394 Firewire (4-pin)
1 Consumer IR
Kev
Posted on: 04 August 2009 by Former member
The Dacmagic, Musical Fidelity v-dac and the Beresford 7520 all have USB, which is what your laptop has.
They are all well reviewed in the mags. The v-dac is now the cheapest.
Posted on: 04 August 2009 by pcstockton
I highly recommend buying a Beresford USB DAC from Stan. He will take care of you.
Posted on: 05 August 2009 by kev 1966
So a recommendation for the Beresford anybody else using anything else?
Posted on: 05 August 2009 by Former member
Yes, I'm using the v-dac, and very happy with it. Haven't heard the others so I can't comment on how it compares.
Posted on: 07 August 2009 by kev 1966
Anybody else, looks like a Bersford
Posted on: 07 August 2009 by james n
The Beresford seems very well regarded. Cambridge DAC2 and Russ Andrews does some of the Fubar units. Any of these are a good way of dipping your foot in the water with computer audio. Be warned - once you try it there's no going back Big Grin
James
Can anybody explain the difference between
SPDIF and USB?
I understand they are different outputs on my laptop, but reading other threads USB appears poor is this the case and how do I know if my laptops supports SPDIF
Kev
Posted on: 07 August 2009 by pcstockton
Kev,
The differences are huge. USB is a way to connect something to a computer. sPDIF is digital coaxial cable typically used to carry audio.
But i am guessing your question is asking about how they sound???
I would guess identical, but most here would say sPDIF is superior. It is nice to have both options...
Listen to both and please let us know your findings!
It is inexpensive to run USB from one room to another if you want your computer far from your kit.
-patrick
Posted on: 07 August 2009 by Former member
SPDIF is actually the data link layer - see spdif definition for more info. It is used for both coax and optical cable.
Some laptops, including most current macs, have a combined headphone/optical, known as toslink, out so can be connected directly to the DAC using optical cable. Coax is less common.
Your laptop's manual should be able to tell you whether it can do this. A general rule of thumb is that older laptops do not have this facility.
Posted on: 07 August 2009 by Exiled Highlander
Kev
I can't comment on the others but the USB connection on the DAC Magic is absolutely dire...and I mean unlistenable (at least one the one occasion I tried it from my MacBook Pro)
It sounds great via Toslink from a Mac though.
Jim
Posted on: 08 August 2009 by kev 1966
Ok,
this laptop doesn't have a spdif output is there any other way of trying digital without the expense of buying a new laptop / mac ?
adaptor ?
Kevin
Posted on: 08 August 2009 by Former member
Yes, m-audio make a USB/toslink converter for about the £60 mark. Google m-audio transit, you should come up with the info.
Posted on: 08 August 2009 by james n
A cheap USB to toslink converter is going to give the same results as USB straight into the DAC. USB if done properly works well but this is basic synchronus USB. You have Firewire and this will give you better options later on if you want to experiment more.
One more DAC, though a bit more expensive is the Devilsound USB DAC.
James
Thanks James, I suppose my question is. Is it worth trying the Usb or do I try another laptop. Where can I go with the Firewall?
Kevin
It's certainly worth trying - for £150 or so and the Beresfords easy to sell on if you want more. There are a few DACS that use Firewire and if you have a computer that will support it then its a very good interface to use. Does Beresford do a trial period ?
James
Or try the v-dac at £130, which is equally easy to sell on.
The other alternative is to buy a dac and an Airport Express. This will give you far better quality than USB and the same or better quality than an optical cable or coax from computer to DAC. Cost is about £80.
Also, if you want to save on the DAC, the Airport Express has one built-in. Not equal to those others mentioned, but not bad nevertheless. Plus, of course, it's wireless.
Posted on: 08 August 2009 by nap-ster
See if your laptop does a docking station. They often have an SPDIF on them.
