What is the right way to go......
Posted by: MontyMusic on 03 March 2010
Hi all,
I've been reading threads on here with great interest. I'm both a Mac & PC user and am just about to start building my library again from scratch.
The question is what is the best format to use? I'm happy to have 2 libraries (one for my iPod, the other for my Hi-Fi) as I think 320 MP3 files are fine for my iPod but I know lossless is better for home listening.
I see the HDX uses WAV files but many on here prefer FLAC, AIFF or ALAC files for streaming.
If Naim use WAV then I would assume that this is the way to go and just use iTunes for both my ipod (with less music on due to size of WAV files) and home Hi-Fi?
If FLAC is the format to go with then I'd use my PC with DBPoweramp and Foobar and my MAC/iTunes for my MP3 files/iPod.
Which way forward is best considering I'm starting from scratch (again!) Confused
Posted on: 03 March 2010 by james n
I just rip in AIFF - i use the same library for my mac running iTunes into a DAC snd for my work and car ipods. The iPods just use playlists that i update as i need. Works for me and saves buggering about with different formats.
James
Posted on: 03 March 2010 by pcstockton
FLAC is most ubiquitous but will not play on a Mac easily.
AIFF might be your best bet but definitely not compatible with all players. It will work with everything you mention though.
Posted on: 03 March 2010 by Dustysox
Originally posted by MontyMusic:
Hi all,
Just to say, my NAS an AVA, rips my music into both FLAC & MP3. Thus ticking the appropriate boxes.
