Using a NAP 200 for center speaker ?
Posted by: karyboue on 20 March 2006
I change my NAP V175 for 2 NAP 200.
Here is my center speaker, a complete triphonic system :
I have several connecting solutions but I use this one : left and right channels going first to the sub (3.5 Naim speaker cable) then out of the sub to the speakers (2m Naim speaker cable).
Is it ok to modify the SNAIC cable by welding channel 2 on channel 1 on its AV2 connexion side in order to have left and right channels inputs of the NAP supplyed ?
Is there other, better solutions ?
Posted on: 21 March 2006 by Stuart M
I've used a NAP 140 with an adapted SNAIC to drive a pair of horizontal IBLs as centre with good results. Curently using one side of the 140 to drive an SBL as centre and IBLs at the rear.
No probs adapting the SNAIC if you can solder.
Posted on: 21 March 2006 by karyboue
Thanks.
It should arrive tomorrow.
