imac / itunes
Posted by: floid on 09 December 2010
I have an imac and want to input all my CDs AIFF or Apple Losslees or 320 what would you good people suggest New to this computer thing
Posted on: 09 December 2010 by pcstockton
AIFF or ALAC.
Posted on: 09 December 2010 by floid
Which is best or should I just stick to my CDs. Is CD better sound quality regardless of what file type
Posted on: 09 December 2010 by garyi
Depends what you want to do with the data.
If its purely to play back via digital out on the mac or from the mac ALAC is fine.
If its to distribute to naim devices, sadly they do not support ALAC.
Posted on: 09 December 2010 by jadip
Take some time and Google "computer audiophile" in quotation marks as shown. You will find a site that will help you understand all of the different choices that are available to you. FWIW, in my case, I have gone away from CD's and now use computer audio exclusively.
Posted on: 09 December 2010 by Tog
Once you start there is no going back - the convenience and the quality of CA is addictive.
Tog
Posted on: 10 December 2010 by PBenny1066
Floid,
storage is so cheap now, I can't see any reason to go for any of the "compressed" formats, such as Apple Lossless. AIFF is uncompressed and also is a format which stores all the "metadata" - track names etc..
Cheers, Paul
