Can u run a Snaxo/burndy off a 52ps?
Posted by: Richard Paget on 02 April 2003
Well that's about my question.
Can you,can you really, can you?
views welcome
Regards Richard
views welcome
Regards Richard
Posted on: 02 April 2003 by Jo Sharp
Believe the pin arrangement in the Burndy differs for 52 -SNAXOs- CDX - check with a Naim dealer or the service dept at Salisbury.
Jo
Jo
Posted on: 02 April 2003 by Martin Payne
Richard,
I have asked this question directly of Naim, in regard to the SNAXO3-6. I'm not sure if the SNAXO2-4 would give a different answer.
Basically, the 52PS does not have enough power supply lines (the SuperCap has more). It *might* be feasible to have further regs added at Salisbury.
The killer, though, was that you would need to buy a custom-made Burndy. The SNAXO burndy is different to the 52 burndy, but a 52PS-to-SNAXO burndy would have to be a custom-made job, and they would *not* modify an existing lead.
It may be that the SNAXO2-4 uses less power lines than the SNAXO3-6, so maybe the PS wouldn't need to be hacked about, but the cost of the custom burndy would still be a real downer!
Can I ask you to e-mail me (address below, replace "at" with "@", remove the spaces).
cheers, Martin
E-mail:- MartinPayne at Dial.Pipex.com
cheers, Martin
