CD or Cap
Posted by: Peter Stockwell on 06 April 2001
You cannot expect to build a fantastic system on anything less than a great source. Peter, I'm not dissing your Stage 6, but you also have synergy to consider. I agree with your dealer. If you don't have the cash now, start saving (or sell a family member)... capping your Nait will certainly improve it, but will throw your system further out of balance.
Forget flash interconnects - the emporor's clothes of the hifi game. People use them as tonal filters (of all things!). It's way more simple than that - just buy the right box, connect it up with the cable it came with (or if it's RCA-jacked, use Naim ARO cable)... listen and enjoy.
In fact for little more than £300 you could buy a used CD-3, which would at least set you on the synergy path and likely put a beeeeeg grin on your face!
Any idea which voting button I hit?
Rico - all your base are belong to us.
But as others have pointed out, better let the Nait settle in first.
Peter
I think that I can be satisfied with current LP reproduction, although I have a lurking desire for an Incognitoed or originlived RB250 as a tone arm. The CD player gives some great results especially with well recorded CDs. I'm actually going through a massive CD reduction program, sorting out the dross that has accumulated over the years, some recordings just sound so dead, or the music is so dated that they're not worth keeping. I can't help wondering that if a let some of these CD's go, if a better CD player might not reveal hidden musical enjoyment in the discarded CD's.
Thanks for all of you that voted
Peter
I found a shop that is called:
C.O.M. (Centrale d'Occasions Multimedias),
9 rue Trois Fuseaux
17000 La Rochelle
This is where I sell unwanted CDs, they take 30% commission. Sounds like a lot ? Well you get to decide how much a CD is worth, so what you stand to get is generally better than those stores that buy for resale. They take LPs, PCs, Video games, radios, TVs. Almost anything vaguely related music or video.
You can find gems there, but nothing is sorted and there is a lot, especially in the LPs, that is only fit for the dumpster. I've managed to sell about 90% of what I've taken there.
Peter
