x-box 360 on-line
Posted by: john R1 on 31 December 2006
anyone know how i connect up x-box to go on-line, at the moment am using wireless connection from tv-drive to receiver which sits by the computer, but the lead and connection from x-box are differant to the leads from the wireless receiver, do i just get another wireless receiver with adaptors or do i need something else, ?
Posted on: 31 December 2006 by neil w
john
you can go ethernet way ( if youve a long enough cable )
or the microsoft way £60
http://www.play.com/Games/Xbox360/GENBRW/3-/719752/Offi...Adaptor/Product.html
i use the official adapter with no problems at all
hope this helps
neil
add = linksys do an ethernet to wireless gaming adapter, not sure on cost, but have heard good reports. lynksys wga54g
Posted on: 31 December 2006 by Roy Donaldson
John,
I'd highly recommend going the Microsoft wireless adaptor way. There's connectors on the back of the xbox 360 for it to plug right into and a USB port to connect it up to.
When I got mine, I plugged it in and went into the xbox to go configure it up and by the time I'd found the right menus, it had found my Linksys router, associated to it, got it's IP addressing and was downloading a firmware update to my xbox already !
Much easier than an ethernet to wireless bridge. You may end up saving yourself a fiver and getting yourself 4 hours of pain if you go that way.
Roy.
(PS, I kinda know a bit about networking as well :-)
Posted on: 31 December 2006 by john R1
thanks for the replys, where is the best place to buy the microsoft device, and do i need to buy anything else to go with it ?
John,
Depends. If you want it cheapish, go online and order it from amazon, or dabs or someone.
If you want it today, nip out to Game or another local game store and pick one up.
If you've got a wireless router on your DSL/cable line already, the adapators then all that you'll need.
Roy.
john
you can buy the microsoft one anywhere
hmv ,game ,gamestation to name a few
you dont need anything else
like roy says its simple plug n play
if your wireless is locked down you just enter your id and wep key
neil
once you get online you can play old x box games if they have support
you just put your game in , the screen will say "update available for this game do you want to download "
click yes and youre away . upscaled old games , halo looks quite good
presume i have to sign up to x-box gold once i have bought the device, as it seems the free silver membership has its limitations
just got one from pc-world for £49.99 said they had run out of the free england face plate, noticed he should get one month free on-line, then around £34 pound a year, will try it out tommorrow as am going to work very soon, thanks again for your help.
Posted on: 01 January 2007 by john R1
plugged the device in, its asking me for the wep key number, any ideas what that is ?
Posted on: 01 January 2007 by Roy Donaldson
One your wireless router, you will have configured wireless security, generaly WEP, you need to put that number into the xbox so that your router will allow it to connect to it.
Do you know what WEP key you'd set it up originaly with ?
Roy.
roy, just going to have a look in the loft see if i can find it among the computer bits, tried ringing telewest must have a skelton crew on today as i got fed up waiting for someone to answer the phone.
roy can understand what you are saying but where can i get that number from, spoke to telewest, about as much help as a dead kipper ?
John, let's take this off the forum. email me at rdonalds@cisco.com.
Roy.
roy, one last point, x-box is not plugged into my computer does it need to be, or should i try it through the computer anyway.
Posted on: 02 January 2007 by john R1
have solved the problem, moved it into the front room, near the sender unit, must admit looks good through pwd6 ay 720p, and sounds pretty good through the n-vi
