Speaker cable question - capacitance, etc.
Posted by: Top Cat on 18 September 2002
Hi folks.
Just a quick question. I have an idea for a readily available cable to make speaker cable out of - and as far as I can tell it would work, but not being as up with the electronics as some around here I thought I'd run it past and see if this would be suitable for a 'standard' power amp/speaker combination*:
Capacitance: 6.0pF/foot (I'd propose 9 feet or so, twisted cable with two strands, each strand containing a number of wires which could be wired either as single or bi-wire)
Inductance: 0.1 uH/foot
...I'm not sure the implications of the capacitance with regard to a normal amp as it seems kinda low - would I be right in thinking this could strain a (say) 23wpc amp?
Thanks,
TC '..'
* It's not a Naim amp, so arguments about guarantees for me don't count - however, if this hypothetical cable would drive most any amp into difficulties then please speak up!
TC '..'
"Girl, you thought he was a man, but he was a Muffin..."
Posted on: 18 September 2002 by Martin Clark
For the sake of comparison only, NACA5 is max 20pF per meter, which is almost exactly 6pF per foot, and 1.3-1.5uH per meter, or 0.4uH per foot. Low capacitance is not a strain for your amplifier - high C is, provoking instability. For example, the recommended maximum length of NACA5 for a Naim amp equates to c.200pF; but many other amplifiers can be tolerably stable into 10s or even 100s of nF. It's simply a matter of design and performance tradeoffs.
What is this 'readily available' wire? Usually for a given wire and insultaion low capacitance = higher inductance, and vice versa, since it depends mostly on material geometry. Your figures are unfeasibly good, suggesting a velocity of propogation slightly exceeding the speed of light...or my maths needs checking wink
M.
Posted on: 18 September 2002 by Top Cat
Martin,
It is undeniably very very good wire, and not cheap (but compared to what it would theoretically outperform it would be a bargain).
Email me if you want to know - I wouldn't want to say too much just yet, in case my source gets wind of what I'd do with their, ahem, product...
wink
TC '..'
