CDS2 PROBLEM
Posted by: Van_The_Man on 28 January 2003
Hi
My CDS2 has suddenly started rejecting the odd CD ( displaying the 'ERR' message ). its infrequent at the moment , but is there cure\work around?
T.I.A.
Neil
T.I.A.
Neil
Posted on: 28 January 2003 by J.N.
Neil
A friend's CDSII started doing this a few weeks ago. Its 'refusals' became more frequent and then it died!
My CDSII deals happily with everything I put in it, but I do keep the puck and platter clean with blu-tack. Spinning the puck rubbers can help.
Posted on: 28 January 2003 by Onthlam
My CDS2 died a month or so ago. Needed a new transport. Nana did a wonderful bit of surgery.
Sounds great!!!
The symptoms are the same. ERR...all the time.
Mine has skipped a bit with the new copy protected cds. I hate it....
Regards to all,
Marc
Sounds great!!!
Regards to all,
Marc
Posted on: 29 January 2003 by Rockingdoc
my CDS2 is very sniffy about playing CDRs frequently displaying ERR when starting up , and CDRWs are an absolute no. I am aware that Naim say their CD players are designed to the "Red Book" standard, but why does every other CDP I own, ranging from high end to very low end, play all CDRs without a problem?
Posted on: 29 January 2003 by Martin Payne
"my CDS2 is very sniffy about playing CDRs"
RD,
the brand of discs makes a lot of difference, IME, and so does recording at low speeds.
cheers, Martin
E-mail:- MartinPayne at Dial.Pipex.com
RD,
cheers, Martin
Posted on: 29 January 2003 by Fraser Hadden
This statement that the CDS 2 is sniffy about playing CDRs is very worrying. I am on the cusp of the upgrade from CDS 1 to CDS 2 and have lots of CDRs.
Is the observation generalisable or a one-off finding? The CDS 1 has exhibited no problems.
Fraser
Fraser
Posted on: 30 January 2003 by Derek Wright
I have not had a problem playing CD-rs on my CDSii apart from the very first ones I made - I then upgraded to the latest verson of the CD writer software and they have all played successfully - even used it to rescue commercial disks that would not play on the CDSii because of manaufacturing fault, yet the copy will play - my recorder only works at 4x max for writing so that is what I record at with "no name" cheapest CDrs.
Derek
Derek
Posted on: 30 January 2003 by Richard Dane
The CDSII should play CD-Rs without any problems (as should all our CD players). For optimum quality try to use decent blanks. With 74 minute TDK CDXRGs available widely at around 49p per disc there's no excuse for using anything less. Also try not to write at more than 4x speed. In my tests this seems to be the best compromise between speed and quality.
Problems may arise with cheap CD-Rs which are poorly manufactured. Sometimes the central section of the disc can be frighteningly thin and the puck can have difficulty gripping the disc resulting in an ERR message. Gently teasing out the rubber grips to their full extension can usually cure this.
Oh, one more thing, try to steer clear of 80 minute (700MB) CD-Rs. They'll play but there are noticeable audible losses compared to their 74 minute (650MB) counterparts.
Posted on: 30 January 2003 by jpk73
CDRs with CDS1 / CDS2
I upgraded from CDS1 to CDS2: it's really more than worth the money, especially if you purchased the CDS1 second hand (as I did)...
My CDS1 played almost all CDRs I burned with my Plextor writer. I use only Mutsui CDRs because I had very bad experience with noname CDRs. The CDRs which caused skipping on my CDS1 were nonames, but these now play without any problems on my CDS2!
I would recommend to burn CDRs with half of the max-speed if possible, but not faster than 8x. If burn-speed is to low it also may result in difficult-to-read-disks...
- Jun
- Jun
