how much is my Naim costing me?
Posted by: AL4N on 26 January 2004
A CDX
2 x 135's
2X hi-cap
and an 82
i wonder how much it's costing to keep it all switched on?i'm sure my electricity bills have gone up since i got my current set up.
Posted on: 26 January 2004 by blythe
Top quality music is priceless.
If you feel it's costing too much to keep your kit turned on, maybe it's time for a downgrade......
A night-light is typically around 10 watts. Have a couple or few of those burning, or security lights (normally 300-500 watts) burning part of a night, and Hi Fi uses a negligable amount in comparison!
Computers are supposed to work on 1's and 0's - in other words "Yes" or "No" - why does mine frequently say "Maybe"?......
Posted on: 26 January 2004 by J.N.
Someone stated here in the past, that each powered item averages about 20 watts.
So; you're only talking about running a couple of light bulbs 24/7.
Peanuts, for your musical pleasure.
Posted on: 26 January 2004 by seagull
Obviously it is the 82 using so much juice by needing 2 power supplies. Replace those hi-caps with a supercap and you won't care about the cost!
Posted on: 27 January 2004 by Roy T
Cut you bill in half by playing only mono recordings.
Roy
Posted on: 27 January 2004 by Tarquin Maynard - Portly
Save money on personalised number plates by simply changing your name.
SN 02 KXS
On the Yellow Brick Road and Happy
Posted on: 28 January 2004 by Rasher
Cut your bill by listening to your system every waking hour for three months, and then turning it off for the rest of the year.
or
Sell all your CD's and replace them with only Barry Manilow and Neil Diamond, then you won't want to play anything and can turn it off permanently.
or
Assume it costs you £50 to keep turned on, and charge it to your next job as a hidden expense.
or
Wait until the neighbours go on holiday, go under the wall and take a spur off their ring main.
Posted on: 01 February 2004 by AL4N
or
or
or
this idea may work
