Cable Question
Posted by: Steve G on 01 May 2001
I'm having some problems with my 92R/90.3 at the moment - one of the amp channels appears not to have any appreciable gain. I think one of the channels on the power-amp is blown but it could also be a cable problem (unlikely as I'm getting sound on both channels) or a problem with the pre-amp and I'd prefer to confirm which it is before sending the kit in for repair.
I have several RCA to 4 pin DIN cables I use for connecting non-Naim input devices to the pre-amp, could one of these be used to link an RCA plugged pre-amp to the Naim poweramp or conversely a RCA plugged power-amp to the 92R? I have an external power supply I can use for the pre-amp.
Or should I just bite the bullet and send the whole lot in for repair?
Steve
