I Like Memory Playback? (J River)
Posted by: pcstockton on 13 September 2010
I have been reluctant to create this thread as I have never experienced a difference regarding sound quality between ANY media players. I have tried almost every widely used player that works with Windows.
- WMP
- iTunes
- Foobar
- Winamp
- J River
- Media Monkey
- Cplay
- XBMC
- XMPlay
- VLC
- Songbird
- VUPlayer (i think it was called)
etc....
None ever sounded any different to me, assuming bit perfection and everything else standardized. So I have always used Foobar as it allows for the ultimate in customization, the fastest performance with huge libraries, and the best UI imaginable.
For the last few weeks I have been trying J River Media Center after I read they now have "play from memory" as an option.
I have only ever tried this with Cplay, but its interface and reliance on cue files disqualified itself regardless of SQ. Honestly though even when I did use this for a few days I did not notice any improvements. If anything there was something I didn't like about it. Maybe it is the resampling you are forced to use... who knows?
In any event, after a full day with JRMC 15, I was noticing a bit more cohesiveness or tightness to the presentation. Also, the spaces in the music seemed quieter. Lastly, the "attack" on snares and other extremely dynamic sounds are quicker on the front end.
Please keep in mind that these differences are VERY subtle, but noticeable. The only thing I can chalk up the differences to would be the memory playback, which I did not de-select for a comparison. I will give that a shot this week.
At this point I am thinking of using JRMC as my reference player, i.e. when no one else is around.
I will continue to use Foobar when I have friends over (often daily). They can use the Remote app to select music on their own iPhones, it has lyrics which everyone loves, an easier ability to setup an ad hoc playlist (add to playback queue), and on screen bio etc... Plus it is simply lightning quick, much faster than JRMC.
The downsides to JRMC:
- Weak iPhone app
- While customizable, not as easily or as deeply as is offered by Foobar
- Slower than I would like, especially in "Theater View", which is the only way I will use it. (although it is faster than iTunes)
- No lyrics
- No on-screen wiki bio/artist picture
- Costs $50
- There are some idiosyncrasies I just cannot get past in "Regular View"
- Doesn't offer "Directory Structure" as a sorting method. This is fairly crucial to me as I search by "Artist View", and want to see the library sorted as I have them stored on my hard drive. For example, I have Funkadelic and Parliament in the same folder and therefore show up together in Foobar. Or people like Miles Davis, who might be tagged as Quintet, Quartet, with Gil Evans, with Coltrane etc..... I want all of my Miles albums shown together rather than 7 different artist entries.
The Upside to JRMC:
- It simply might sound a little better. ( i cannot believe I just wrote that)
- I haven't tried WAVs yet, but I have read it handles them well.
Give it a shot if you haven't tried it before.
I don't think anything is going to fully usurp Foobar for me in the near future, but I do hope someone develops a "play from memory" component for Foobar. That is, if that is reason I am enjoying the SQ of J River.
-Patrick
Posted on: 13 September 2010 by james n
Good report Patrick - i'm suprised more of these players dont use memory play. The benefits i've found with pure music and memory play were very worthwhile.
James
Posted on: 13 September 2010 by likesmusic
Assuming both sources are bit-correct, does this experience imply that there is a strength in JRMC, or a weakness somewhere else in the replay chain?
Posted on: 13 September 2010 by Graham Russell
I've been "banging on" for ages about the audible differences between software players. Also, WAV and FLAC do sound different. There is something going on with the real-time decoding of FLAC which makes it sound different from the processing of uncompressed WAV. Internally each product is using maths to process the source audio file and create the bit stream and pass it on to the DAC. J River promote the quality of the maths within their product.
I have both Foobar and Media Center and the latter certainly sounds fuller when playing the same source file.
As an aside, my personal preference is to run MPD under Linux. Much more tricky to set up though as it requires editing config the MPD file to define the output device etc. To my ears this is a significant improvement over anything I've tried under Windows. Don't know what the differences are, but it sounds better.
Posted on: 13 September 2010 by pcstockton
Like where for example? And yes obviously....
The weakness, as implied in my message, might be the lack of memory replay with Foobar.
Posted on: 13 September 2010 by Mike Smiff
Patrick, I have tried most but not all of your list of players and my preferred player is JR15 because of the memory playback sound quality, Flac = Wav files to my ears something I had never got to grips with before and had always prefered Wav or Aiff.
Flac for me is the preferred medium for storing on external drive with its metadata and artwork support and I found wav works well if storing on a laptop/pc, the metadata and artwork are there but not if I transfer to external drive.
Flac will of course save some space without any quality loss if playing back from memory (ram dependent) but is no use if you want to store your collection on an i-pod as J-river converts it down to the lowest quality mp3.
I think I need more than one pc and or better network drives if I am going any further with D/A. I would love hear JR15 0n a better dac or the new NDX client when it hits the dealers, I have high hopes I may be converted from CD playback at some future point.
I also prefer the bundeled in ASIO as an output mode over any other options via M-audio Transit.
DBpoweramp/J-River mc15/ windows7 just work well together, heck it even works O.K. on my older under spec. Vista lappy.
Posted on: 13 September 2010 by Bananahead
Which sort of memory sounds best?
enough to buffer the song i guess.....
what are you using?
I agree
Posted on: 14 September 2010 by Hot Rats
Hi Patrick
I prefer the sound of JRMC to Foobar2000 but it is a marginal thing. I also prefer the interface but that is a personal thing.
I have experienced some problems with stuttering on playback with JRMC. I have posted on JRiver's 'Interact' forum.
Matt from JRiver seems committed to resolving the issue as it seems that there are a few users having this problem.
Posted on: 14 September 2010 by Mike Smiff
what are you using?
Cambridge Audio Dacmagic, I wanted to get computer audio sussed before spending real money on a dac, and clad I waited as I think the NDX might be a better product for my setup.
Posted on: 14 September 2010 by Holty
- WMP
- iTunes
- Foobar
- Winamp
- J River
- Media Monkey
- Cplay
- XBMC
- XMPlay
- VLC
- Songbird
etc....
- Weak iPhone app
- No lyrics
- Costs $50
The Upside to JRMC:
-Patrick
Patrick,
Due to issues with Foobar and the HiFace i switched to JMC15 a month ago and i thought i could here differences. It just sounded more open to me but with tighter bass.
I thought it was a placebo like effect however SWMBO commented the other-day how good it's been sounding for the last month so i am starting to be convinced that JMC is better.
I have also switched Kernel streaming instead of ASIO4ALL and WASAPI.
I'm expecting the EVO this week so I'm going to try them both with JMC and Foobar just to see if I'm not mental!
Posted on: 14 September 2010 by js
Just retried MC to check out the memory play. It is better but I still prefer MM. Both were set in ASIO exclusive via a TC/DAW with all gapless, fade, etc deafeated. MM was set to time critical and 16 buffer size. Played with buffer size on MC to see if the issue was there. The memory playback made MC less ringy and better timed but it still wouldn't be my first choice for PC player tough it's now pretty good. Memory play did allowed a min buffer setting without issue so it's obviously doing something though wav vs FLAC was still apparent. Wavelab still surpasses both.
All IMO. Your maileage may vary.
Posted on: 15 September 2010 by js
Just as a note. Buffer at 8 on MM can be better if you need it a bit more etched and I'm not sure I wouldn't still prefer Foobar to MC. Maybe your inboard card interaction or OS has something to do with our differences of opinion. I've always foung MC a bit too glassy for me in every setup I've tried it in.
PC, I'm not saying that you're wrong and this stuff is opinion. Many use MC happily. Are you using tos or the break out cable (which always bugs me
)? Have you tried setting the Juli@ buffer to 512? ASIO?
Posted on: 16 September 2010 by Holty
Patrick,
I've been experimenting with memory playback and i'm not sure if i like it? (not that it matters to you of course
I'll tell you why..
It certainly cleans everything up, the sound-stage seems a lot more controlled and detailed however i think (on my system anyway) that it loses the excitement? almost like it's turning it into something beautifully presented but very removed safe and clinical?
From Naim to Electrocompaniet?
loss of PRAT? or maybe i'm being a prat
Posted on: 16 September 2010 by js
Funny, because I thought it had better timing but just less bright. Holty, you should not have needed ASIO4all along with wasapi. Wasapi alone should be best. ASIO4all is Kernell streaming in an asio wrapper and I think worse than either. Both just add a layer to wasapi which is always in play. They can still be pretty tranparent. The wasapi plugin is about accessing it directly without need for additional kernel, asio etc. By the way, I just tried the foobar wasapi plugin on a customers PC. Instantly worked great. I couldn't play with it for long but I could direct other sound functions to the onboard sound card via the control panel so at least somewhat exclusive.
Posted on: 17 September 2010 by Holty
Hi JS,
I don't think I use ASIO or WASAPI at the moment as I haven't got them installed any more? I installed the HiFace driver and used Kernel streaming option?
When the issues started with Foobar/ WASAPI / Hiface on my system i flattened it and re-installed everything including the OS.
Are you saying that Kernel streaming is infact ASIO4ALL?
Posted on: 17 September 2010 by js
I believe asio4all is using kernel streaming to mimic true asio so it's neither really. If you have W7, wasapi alone should be best.
Posted on: 17 September 2010 by pcstockton
PC, I'm not saying that you're wrong and this stuff is opinion. Many use MC happily. Are you using tos or the break out cable (which always bugs me Winker)? Have you tried setting the Juli@ buffer to 512? ASIO?
I am using toslink out to the nDAC. And yes using ASIO2.0
I dont know what buffer the Juli@ is set to, I will check later. I can say I have never had even one drop-out, click or pop with the Juli@.
Regarding buffer... do I set that in Foobar or in Juli@ settings?
Lastly, you mention above that you defeated gapless. Did you mean you defeated fade and whatnot, and set everything to gapless?
Thanks.
Patrick
I heard a CDS2 into a Electro preamp, out to active PMCs and it was pretty nice.
The owner also has a full 500 active system into DBLs.
Are they not a good match?
-P
I like Electro, but it can be a bit too refined from the stuff i've heard for my own taste..
horses for courses etc etc
Posted on: 18 September 2010 by js
Thanks.
Patrick
In the Juli@ panel to see if you happen to prefer another buffer setting and yes, I defeated everything just to make sure I wasn't listening to features and any extra buffers that may come along.
This is going to sound crazy but we had a customer come in today with a Halide bridge/W7/MC arrangement for a DAC audition and I did some setup for him with the wasapi, memory play and feature settings. We tried adding fadeout settings back in to see if would eliminate a very minor tic at stop which he has with every DAC. It didn't but fast fade was the preferred sound of all the options.
We didn't try it for sonic reasons but it was noticable. Of course this was via a 500 series setup
but still baffling. I'll listen again with my own xp laptop again, not assume everything out of the loop is best and see what I come up with.
Posted on: 18 September 2010 by pcstockton
Mine has been on 512 since initial setup. I will play with some other setting while I prime for Willie Nelson concert tonight!!
Red Headed Stranger on now...
Posted on: 22 September 2010 by js
So my views haven't changed except that I think I may be able to get the most out of Winamp. Should be the same as MM but for XP it seems a hair better and also handles wave files well. Foobar is also preferred to MC for me but if it can't do wav easily it's kind of a waste. I'll play with some skins and see how Winamp is in use. Wavelab is still the one to compare against.
Posted on: 22 September 2010 by pcstockton
My views haven't changed much either.... JRMC has a very slight edge possibly due to memory play (the only real difference). Although it is not significant enough to replace Foobar as my everyday player. Shit, i might be imagining it all anyway. However I am now wondering about my Foobar set-up.
For one, with ASIO output, why does the internal Foobar volume work but JRMC doesn't?
Also, ONLY Foobar makes a audible glitch (digitized "slur") when minimizing the program, while JRMC does not.
It makes me wonder......
-Patrick
PS - Willie kicked some serious ass. I cannot believe how old that guy is and still killing it.
