52 phono stage
Posted by: vimal on 10 November 2002
Which 52 phono cards is suitable for use with Sumiko Blue Point Special.
Thanks in advance for all replies
Posted on: 10 November 2002 by JosephR
MM phono card ...
Posted on: 11 November 2002 by Rico
do you
really want to use a BPS?
Rico - SM/Mullet Audio
Posted on: 13 November 2002 by vimal
do you really want to use a BPS?
no I dont
The question was to help someone who has just got a 52.
Posted on: 13 November 2002 by Richard Dane
Vimal,
your friend should order some NA 522 phono cards from the nearest Naim dealer. If you or your friend take along the NAC 52, the dealer should be happy to fit them for you.
Posted on: 14 November 2002 by vimal
Thanks Richard
