Nait3 vs. 32.5
Posted by: Mike Cole on 27 April 2001
Mike
Your proposed combination of 32.5 (72'd and board pulled) and 140 should considerably outperform the Nait3.
The 32.5,once 72'd,really is one of the Hi-Fi bargains of the centuary.
The 140 is both musical and well respected.
But,I have to point out that although you can power the 32.5 from the 140,it will only really start to "sing" when a Hi-Cap is used to power the 32.5. (but even used as a basic pre and power only,I would still expect it to outperform the Nait3.
I believe you would be pleasantly supprised at what the 32.5 (72'd) /Hi-Cap/ 140 is capable of
Chris
Would a 32.5 and, say, a used 140 be a *lot* better?
Yes. You don't even need a 140, IMHO a 110 would easily beat it. And when you eventually get a Hicap you are in a totally different league. Given the choice of a 32.5 / 140 and a 32.5 / Hicap / 110 I would choose the later, it would probably only cost about 100 quid more if you shop well (i.e. Loot).
If you are buying a 32.5, try and find a serviced one with the 72 boards already in, as it will save you a fair bit of money later. A bog standard 32.5 goes for about 150-200 quid, one with 72 boards goes for possibly 50 quid more. IMHO that is 50 quid very well spent.
Tony.
I totally endorse everything Chris has said.
There is a significant improvent in performance over the Nait 3 and the 32.5 is a virtual 72 at half the price. Its only downside is that it is black rather than olive green, however, you may consider that an advantage.
Despite their age, most are well cared for, mainly because they have been owned by audiophiles, and the going rate is between £150-£200 depending on how well you negotiate. I paid £170 for a mint one 3 years ago.
You will be very pleased with it and I still use mine in my secondary system and I love it.
Mick
Thanks,
Andy.
Andrew L. Weekes
alweekes@audiophile.com
I did the Nait 3 vs. 72/hicap/140 demo about 3 1/2 years ago and went with the 72/hi/140 combo. Odd thing was that the 72/140 alone (no hicap) wasn't that much better - only marginally so to my ears AND the addition of the hicap brought some negatives with it. The hicap definitely afforded a performance boost but is also added some hashiness to the system. Through the very-revealing ProAcs we were using, this never went away in owning the kit for 3 years.
Maybe it is down to Grey v. Black SNAIC (I had grey, never tried black in my system), but a friend of bought a Nait 3 never had this problem.
Also, I'm not sure the differece is better than a source upgrade. My system did things the Nait 3 system would not, but I bet a CDX/Nait 3 would beat a cd 3.5/72/hi/140 system in many if not all areas.
What source(s) are you using?
- Greg
Insert Witty Signature Line Here
All are better than what I've heard of the Nait, an should be as both the pre and power of a 32-5/140 are substantially better than what's in the Nait.
About the hicap: my system started singing with the snaps. A fundamental improvement that made me want to listen more. It caused much less instances of harshness or tinnyness. The bass was deeper and much more satisfying. The mids were much prettier, and the treble much more natural. Dual railing and recapping made it more hi-fi--tighter and cleaner, but didn't touch my soul.
The hicap transformed the sound, making it much more hi-rez, but wasn't as big a jump for my enjoyment as the snaps, though soundwise it's further from snaps to hicap than from bare to snaps.
Black snaics were also a fundamental change, making everything fuller, less harsh, more lifelike--as big to me as a snaps. Never tried 32-5/140 with black snaic. But with the hicap, putting in the black snaics made the system so much more tolerant of poor recordings, so much less hash and glare, deeper, more detail (but more natural), etc. Greg, it's a shame you didn't try the black snaics.
--Eric
So, while the Black may be better, I decided it wasn't likely to transform things and I wasn't liking what the Naim stuff was doing. So it went.
And there are no good dealers around, so...
Maybe someday...
- GregB
Greg -
My sources are a CD3.5/FlatCap and an LP12/Valhalla/Ekos/17D2.
Mike
