Can someone tell me what I would need to use an IXO in my system?
Can I use Nait 5-IXO-Credos or do I need 2 power amps?
Posted on: 30 August 2003 by effinity
I'm not an expert but know that the IXO crossover has a built in power supply and according to the blurb was designed for use primarily with Intro and Credo loudspeakers. To go active though, yes you will need 2 power amps.
