Touch screen for HDX
Posted by: Jonn on 25 June 2009
I'm expecting delivery of an HDX next week and plan to add an external touch screen. Any views on makes, models, screen sizes? I don't want to spend more than £300.
Thanks for any advice.
Jon
Posted on: 25 June 2009 by Gordon McGlade
Jon
Try this link
http://linitx.com/viewcategory.php?catid=185
I use these and they great value.
Gordon
Also try this
http://www.dabs.com/products/c...een-4RWF.html?fb=103
Gordon
Posted on: 25 June 2009 by gary1 (US)
Please Wait. Your request is being processed...
Logout: forums
Update Groupee Account Reply
I would go with a netbook pc which has an 8.5 inch screen and can work wireed/wirelessly and you get the additional benefit of having a computer. There are many out there in your price range. The ones from ASUS (eee series) seem to be a pretty good value.
Posted on: 25 June 2009 by Jonn
Buenas tardes Gordon,
Thanks for the suggestions. Do drivers need to be installed with external monitors?
p.s. You may have gathered where my HDX is coming from Smile
Posted on: 25 June 2009 by scottyhammer
i pod touch..simple
Posted on: 25 June 2009 by jech
scottyhammer
How do you use a ipod touch with HDX
Posted on: 25 June 2009 by Patrick F
you cant directly.
it can only be used through a naimnet system.
Posted on: 25 June 2009 by David Dever
Elo 1515L is also a fantastic match (about $460 USD):
1515L Multifunction 15" LCD Desktop Touchmonitor
