turntable setup problems...
Posted by: Alco on 02 September 2001
I have the following problem:
My system really has to stand in between my Kan's.
But since there's also a fireplace in between them,the system support has to stand in the middle and in front of the Kan's.
(I hope you guys understand what I'm trying to say)
Now,if I want to get me a TT (and I still do) I have to place in on top of the already 63cm high system-support.
I can imagine this would have a negative influense on the sound,since the TT would be on the same height as my Kan-II's.
Now,
I do have a sturdy piece of pinewood furniture (looks a lot better then the system-support and could hide all the cable-apaghetti!)
This piece of furniture is 83cm width and only 49cm high.
Would it be a good idea to put a TT, on a dedicated TT-isolation platform,on top of the pinewood furniture ? This way the TT would be at a lower level then the Kan's.
I made a little drawing to make things clear.
what would be wiser: example-1 or example-2 ?
...Thanx,Y'all!
[This message was edited by Alco on SUNDAY 02 September 2001 at 14:20.]
[This message was edited by Alco on SUNDAY 02 September 2001 at 14:21.]
