What's your experience with second hand audio?
Posted by: djorg on 25 April 2005
Anyone here have buy second hand naim audio or can tell me anything about that?
is internet(i.e.:ebay) a good way to explore? what's your experience?
Djorg
Djorg
Posted on: 25 April 2005 by Tim Danaher
Djorg --
Bienvenue au Forum!
Naim is an excellent second-hand buy, due to the servicing and backup, but it may cost you more if you have to send it to Salisbury from France. Also, buying Naim S/H, you generally won't lose money if you decide to sell it on.
I'll PM you with the url of a good S/H 'flat-earth' site.
Bienvenue au Forum!
Hmm. No I won't. How do you send PM's now? I've added djorg to my buddies, but clicking on his username in the buddies list just takes me back to his profile.
Anyway the link is here
Don't know if this now contravenes posting rules. Sorry.
Posted on: 25 April 2005 by Berlin Fritz
It doesn't sound as good as new
Posted on: 25 April 2005 by Tam
I've had some very good experiences with second hand kit. With naim especially, it's a bargain and it holds its value very well. I've bought a tuner (a lovely NAT 101 & SNAPS, I won't buy naim's current tuner as I want a tuning dial - silly reason I know), a pre-amp (nac 32.5, which has just been serviced by naim and sounds glorious) and a NAP 250. I've used a mix of pink fish and ebay (though I always feel a little wary on ebay, it's proved safe).
Naim's service department is another excellent point about buying second hand, since they'll make something as good as new again.
However, it's worth making sure you check various things to make sure you're not being scammed (if you do a quick search you should find plenty of advice on the subject of using ebay).
regards,
Tam
Just changed "scanned" to "scammed" - hope that was what you intended.
Adam
Thanks Adam, it's good to have a pedant on hand!
Tam
regards,
Tam
Adam
Tam
Posted on: 26 April 2005 by djorg
thanks for your post!
Tim:
Merci beaucoup de votre acceuil ! et toutes mes excuses pour mon anglais !!!
Some of us think that s/h naim products do not sound as good as new ones(Berlin) and others think after a salisbury return old naim product sound as new ones.
So, must i ever consider a salisbury return for s/h products? All products need a return (CD player, power supply, tuner, amps...)?
Tim:
Posted on: 26 April 2005 by Bruce Woodhouse
I think it should be pointed out to a newcomer that Berlin Fritz has never owned/heard Naim HiFi. His post was mischevious!
Naim Salisbury will advise when an item should be serviced, they have a record of when manufactured and if re-capped. It makes buying s/h Naim an even better proposition, and partly explains why it holds value.
I have bought a various items S/h including a 52/Scap from Tom Tom Audio (should find it on google search). I'd happily buy from them again.
Bruce
Bruce
Posted on: 26 April 2005 by Berlin Fritz
I think it should be pointed out that I have heard Naim equipment John, and I recently said that I own none at present, just in case I get miss-diagnosed like, innit Chief
Fritz Von My memory is phenominanaomonamal
Oh, my apologies!
Still not sure that our new member should be encouraged to take all your posting literally though.
French for 'pinch of salt' anyone?
Accepted Old Bean, and I whole-heartedly reccommend any new members not to take any postings whatso'ever, literally on this forum, as they do so at their peril. I fear, innit.
Fritz Von Fun Fun Fun Then my Daddy took my T-Bird away
Posted on: 26 April 2005 by charliestumpy
Haven't bought 2nd-hand Naim, but have sold, eventually creating it, and would like to think that purchaser, via Naim excellent support, had got what they wanted.
Have always been delighted with my purchases of 2nd hand Linn (LP12-Kan-Isobarik).
Posted on: 26 April 2005 by ARC
I have purchased most of my system secondhand from Naim dealers who are selling on for other customers. Whilst the obvious benefit of second hand is a financial saving I think that it is also important to see S/H items as a valuable form of recycling. The same can be said for items like guitars and wooden furniture where second hand can be viewwed as saving the world's resources.
Brendan
Brendan
Posted on: 26 April 2005 by Rockingdoc
Bought half my system new and half s/h from dealer. All of the s/h needed service sooner, rather than later, so add that cost in your calculations. Serviced Naim is as good as new.
Posted on: 28 April 2005 by djorg
Bruce Woodhouse:
Thank you for your advice
I'm happy to learn that for most of us Serviced Naim is as good as new.
Posted on: 28 April 2005 by Peter C
Naim is quality kit and thus a good secondhand buy.
Its better to buy quality secondhand kit which is better built and sounding, than new kit at the same price point.
How much new kit at £600-£700 is going to be the equal of a used 72/140 in sound quality?
