iTunes - Help
Posted by: Hawk on 03 April 2005
Ok guys this sounds easy but im making a hash of it and would value some advice from someone who knows how the library works in iTunes/osx.
Basically i use a Powerbook and im just about to run out of memory so i want to use a Lacie firewire drive as the main place to store and access my music. Ive been using the drive for a while as a back up, by just copying the whole music file from the laptop.
The problem i seem to have is that although ive changed the iTunes music folder location in preferences to the lacie, iTunes cant see the music that is there on the drive. I think it must have something to do with the library.xml files?
Ive also tried exporting the library from iTunes, but this seems to export the xml file but not the music ones.
Im sure this should be very easy!????
thanks in advance
thanks in advance
