HD trouble again
Posted by: Steve B on 11 January 2004
I have replaced my hard drive 3 times in the last 3 months. My new Maxtor 80Gb is now making those dreaded clicking noises and failure is probably imminent.
Surely there must be a reason for this. Hard drives aren't normally this unreliable surely?
Any ideas on what could cause 3 HDs to fail so quickly?
Steve B
Posted on: 11 January 2004 by JeremyD
Judging by my experience, this is perfectly normal behaviour for a Maxtor drive*: the one I got three years ago failed twice, after which I gave up and bought another brand. OMG - I should return it for another repair before the guarantee period is over.
I currently have a Seagate Barracuda HD, which has been working perfectly - and quietly - for months.
*I should point out, to avert a lawsuit, that the bad experiences of two people with Maxtor drives is not enough evidence on which to make statistically generalisations - but at least such generalisations give manufacturers an incentive to work towards zero defective products or whatever...
Posted on: 11 January 2004 by john rubberneck
Hi Steve
Best bet is to replace the HD controller which is in affect the mother board unless your using it driven from a card in which case the card, as far Maxtor is concerned I have nothing but good to say about their drives.
Stuart
Posted on: 11 January 2004 by John Sheridan
well you can add another person to your list... I went through 4 of them in about 6 months a few years back. Utter crap.
Posted on: 11 January 2004 by Toksik
Steve B, i guess you've just been VERY unlucky with your Maxtor drives.
i'm curently using a maxtor drive and touch wood it's never had any probs,it's 120GB and split into 2 separate partitions........of course you can always fall back on your guarantee/warranty.
dennis
Posted on: 11 January 2004 by count.d
Steve,
I would take the drive out, stick it in the microwave for twenty seconds, take it back permantly faulty and exchange it for a Seagate. These are regarded as one of the best in the industry.
If you take a noisy or temporary faulty hd back, the seller will go through a long winded process to check your claim.
Posted on: 12 January 2004 by domfjbrown
My mate's been building PCs for the last 12 years...
There's a reason Maxtor are dubbed "Crapstor" by him...
Don't microwave it though - it'll do more damage to the microwave. A short sharp tap with a hammer, or an accidental "vacuum leak" will suffice...
__________________________
Make your choice, adventurous Stranger;
Strike the bell and bide the danger
Or wonder, till it drives you mad,
What would have followed if you had.
