Bad VibrationsFigured it out, normally naim add a little felt to the front/rear of there (powered) extruded cases, to dampen and possibly take any tolerance or lack of stack up...
Well it appears the IXO (may be other Slimline products DON'T !!!), the case was actually rattling quite badly, I realised this by gently pressing the centre of the casing to find to my amazement it slapped against the chassis !!!
Surely cost reductions shouldn't affect Naims ultimate goal of squeezing the last once of audio juice out !!!
WARNING Potential
To all Slimline owners try pressing 'lightly' on the casing to gauge if there is 'slack' between chassis & casing !!!
Honestly, can't BELIEVE Naim would overlook this, maybe it's there lateness in realising the effects of vibration/microphony...
Good Vibrations
For sometime two niggling factors have bugged me with no apparent solutions.
* Right Channel always seemed somewhat subdued a listening levels;
* Inability to listen to anything above say a qtr turn;.
To temporarily eliminate the bad vibrations I wedged some 3M sticky, giving the whole chassis/case a solid one piece feel - I intend buying a few strips of felt tomorrow- to finish the job Naim didn't !!!
Anyway enough frustration - applying my temp. fix has solved both the aforementioned problems, I've been listening most of the evening at around half a turn !!! AWESOME my SBLs are really showing what there made of now...
naheed
(rather pissed off !!!)
