Nait 3 w/flatcap or 5i
Posted by: 74impala on 24 February 2004
I have the choice of either a s/h Nait 3 with flat cap or a new Nait 5i for about the same amount ($50 difference). Any opinions which to go with?
Posted on: 24 February 2004 by gavagai
If you are not a vinyl lover, or if you are, and do not plan on using Naim's Stageline, I would go for the 5i. Just a personal opinion from a current Nait5 owner who has demoed the 5i.
Posted on: 25 February 2004 by Nuno Baptista
Some prefer the Nait 3
Just listen both and decide
MY system : Naim Nait 5 amplifier,Naim cd 5 ,Epos M 15 speakers,Naca5,FC2
Posted on: 25 February 2004 by Eric Barry
The 5i is $1350. $1300 (if you are paying list) seems too high for a Nait 3/flatcap.
--Eric
--Eric
Posted on: 25 February 2004 by glevethan
I echo the above comments regarding the possibility of using vinyl. I had a choice between a Nait5 and a 5i and I went with the 5: I can power the Stageline from it (I just bought an LP12) AND I can upgrade it with a Flatcap which SHOULD make it behave better than the 5i.
Gregg
Gregg
Posted on: 25 February 2004 by J.N.
I'd say John Toon is right on the button.
Do you have a '74 Impala?
If so; can we have a photo please?
Posted on: 25 February 2004 by Justin
What's this about paying less if you are paying "list". Are dealers tacking on a premium for the nait5i?
Judd
Judd
Posted on: 25 February 2004 by 74impala
Eric,
Either I really misunderstood my local dealer or something fishy is going on. I swore they quoted $1100 for a 5i. When I went back the price was $1350.
J.N.,
Don't have any 74 impalas right now. One of my hobbies, other than listening to music, is doing demolition derby. If you're serious I could email you a picture, although the car would be smashed up.
J.N.,
I was hoping you had a nice road going example.
Do you wear ear-plugs during your other hobby, to protect your valuable hearing?
I ride a motorcycle and never without ear-plugs.
J.N.,
I wear a helmut but no ear plugs. Check out
www.essex1.com/people/mccoy/index_files
if you want to see old Chevys
Should I be posting this some where other than the Naim forum?
